Samsung won’t reconnect with data after a trip to the US and using easy roam, mobile data is off, all settings are back to normal, no data connection.
Did you check your APN settings?
Have you tried Restarting your phone
I'm sorry, did you say your mobile data is OFF? Because that WOULD prevent the phone from connecting to data.
