Hi I want to block outgoing international calls from my number how to do it.
Are you a postpaid customer?
If you want to remove outgoing international call, go to your self-serve and remove the pay-per-use international calling add-on.
However, just a note, as a postpaid customer, you can’t block calls to number with country code (+1).
Hi I cannot find that option can you please share the exact pathway to get there thanks I am a prepaid customer
Hi
International long distance calls on prepaid should be possible only if you have a long distance booster added.
Do you have a long distance booster on your prepaid plan?
I did’nt added the long distance booster. I am new to prepaid Kodoo service moved from Rogers. I want to make sure by mistake if I dial long distance calls they don’t charge me like post paid and calls gets blocked due to the feature.
Got it!
If you didn’t add a long distance booster, you shouldn’t be able to call international numbers.
For the US, there are currently some interesting plans that have Canada-US calling included, you can check them here https://www.koodomobile.com/en/prepaid-plans
Login to the community
