how to access voicemail overseas without incurring roaming charges?
Page 1 / 1
From a landline or another mobile phone, dial your area code plus your phone number. When voicemail answers and the greeting plays, press the * key, enter your password, then press the # key and follow the prompts.
If you dial from your cellphone, you will incur roaming charges.
And how may I update my password / passcode?
Are you saying your forgot your voicemail password?
If you forgot your password you can follow the steps below
https://www.koodomobile.com/en/help/voicemail
Login to the community
or
