Cannot change plan rate in self serve
It wont let me change my rate plan to 55$ 75gb with free perk. This thing keeps popping up. I tried waiting hours and doing it on different devices.
Eh, did you try to change the perk or the plan?
I am little confused as you mentioned you had issue with plan change but the screenshot was a perk change.
The new plan comes with a free perk. After clicking a new plan it'll lead me to choose a free perk page, I choose a free perk then error happens.
Could you ignore the perk and move the next step?
I think it was a known issue. you could select the perk after plan change or a rep would help you to do that.
Already tried ignoring it, still thesame thing.
Let me flag a rep to look into it
Hi @Buffy
This is a known issue and our dedicated team is working on it, we are sorry for the inconvenience caused.
We will try to assist with the changes,  we have sent you a PM so we can confirm more details, please check  your inbox when you get the chance. Thanks!
@Flo Koodo I had the same issue and now the 75GB plan is no longer showing in self serve.
@Trochaic What is the perk that you want to choose with the new plan?
@Flo Koodo I’ll choose speed boost. Thanks!
Hi there @Trochaic  We have looked into your account and we can see that you do have the Speed Boost perk on the number ending by *685.
@Boa_Guy Koodo  I know I have speed boost, that wasn’t the issue. I mentioned my issue was the same as OP,  having problems changing to the 75Gb plan. Self serve was giving me problems when I went to change the plan and then the plan disappeared.
@Trochaic  We have sent you a private message with more info.
@Boa_Guy Koodo @Flo Koodo A week after the OP and this is still an active issue. Any ETA on a fix?
@Boa_Guy Koodo Im having the same problem. I cannot switch the plan without having the perk error. How do I get this updated correctly?
@Rubes1  We have sent you a private message for more info, take a look when you get a chance.
@Stacie87  We have sent you a private message for more info, take a look when you get a chance.
