Adding a Second Line to Monthly Plan
  • Aug 28, 2024 12:24 PM UTC
  • 2662 views
I want to add a second line for my son who is going to school. When I go through the steps it makes it seem like it might wipe out my number etc. I want to be sure if I follow the steps that my plan will stay the same and just add a second line for him for the $15 plan. Anyone else have a second line for their kid on their main plan?
Thanks in advance!
Best answer by MilkyWay
You can add a line on your Self-Serve account. https://www.koodomobile.com/en/add-a-line
  • Aug 28, 2024 12:26 PM UTC
  • Member
  • Aug 28, 2024 12:28 PM UTC
And my plan will just remain the same, no changes to it? Other than the new cost of the phone. Thanks for the quick response!
  • Aug 28, 2024 12:31 PM UTC
Yes, you are adding a new line to your account. It should not have any effect on your existing line.
  • Aug 28, 2024 3:24 PM UTC
If you are looking at the $15 plan and it's for a child, I recommend going prepaid with them. This way they can never incur overages.
  • Aug 28, 2024 3:49 PM UTC
There’s a surprising amount of times people come here saying that their children have used a lot of data overages or other such charges. A prepaid plan would prevent that possibility and is a good starting point.
Sophia
  • Aug 28, 2024 4:18 PM UTC
Adding my voice :-) Plus the prepaid $15 plan actually provides twice the amount of data (500MB) and international picture messaging (MMS on the postpaid plan is $$$ for each message). And last but not least - there is nothing to stop the child from going over the allotted 100 minutes and rake up a huge bill that way. Prepaid is definitely the way to go :)
