If I get a new phone with Koodo and do a tab with them, can I keep my existing plan with my current phone or do I have to switch to a new phone plan, the new plans say starting at $70 plus the tab .  My plan I have now is much less than that. I have a phone plan with koodo right now
Is your plan a no-tab only plan?
Also how much is your plan?
https://www.koodomobile.com/en/help/Keeping-or-changing-your-plan-when-you-upgrade-your-phone?srsltid=AfmBOopNoKxmFobLDyqmKvnrJOsVgJylAh9lWNHCwuSkp_pvZjxUWkwN
Yeah It was my own phone brought in when I switched to Koodo so I have no tab. My plan is $45
You can go into your Self-Serve account and choose a phone. It will let you know whether you can keep your existing plan with various Tab choices or change to a different plan.
From the link I posted above it looks like your plan can only do tab basic.
If you can wait, I highly recommend just waiting until the black friday sales in a few weeks.
Oh ok I see it now. I didnt click into the next part because it said phone plans start at 70$ I see where it says you can keep it now. thanks.
