eSim QR code
  • November 20, 2024
  • 10 replies
  • 3798 views
Just found out I need an eSIM QR code for my new phone. Is there some way I can get it online?
Best answer by Nomi
Hey ​@Oliver C thanks so much for the quick reply! A few other questions:
Do I have to use an eSIM? Can I just put my physical SIM card from my old phone into the new phone? Is there a particular benefit to one or the other? How much does an eSIM voucher cost?
I had no clue I had to do anything with SIM cards until I actually transferred everything over. Surprise!😯
  • November 20, 2024
Koodo only offer eSIM vouchers in stores, they do not offer a way to get one online. So you would have to head to your closest koodo kiosk or telus store to purchase one. Just make sure after you aquire one to make the sim card swap in self serve before using the QR code otherwise it won't work. That, or you can ask the rep to do this for you. I hope this helps, more information can be found in the link. 🙂👍
https://www.koodomobile.com/en/help/esim-and-esim-vouchers
  • Rockstar
  • November 20, 2024
  • November 20, 2024
No problem 🙂
So you don’t have to use an eSIM, it is just another option for you as a consumer but you’re correct you can just use your old physical sim if you choose. There are a few benefits to switching to eSIM, some to note are if you travel frequently, you can have multiple eSIM’s on one device and just turn them on and off for whichever country you visit. There would be no need to remove  any physical sim and switch it and potentially lose it.
Another key benefit is security. If your phone is lost or stolen and someone takes out the physical sim card, without phone data on the device it will be difficult to locate the phone using either Find My iPhone or android equivalent. With an eSIM it cannot be removed, so your phone will be easier to locate if lost or stolen.
eSIM vouchers are usually $10 or $20 (they’re usually discounted to $10). If you have any other questions feel free to ask 🙂
  • November 20, 2024
You can absolutely use your old physical sim.
One of the benefits of a esim is that you can set up multiple sims (multiple phone lines) on your phone.  The physical sim slot is limited to 1 slot and 1 number.  This is utilized mainly for travel sims those with a person and a business line.
  • Rockstar
  • November 21, 2024
@Dennis Thank you!
@Oliver C  You truly are legendary! Thanks so much for this info. I especially like the added security an eSIM gives so I’ll toddle down to the nearest kiosk and get one. Much appreciated!
I am outside of canada and lost my eSIM due to replacing my iphone with new one. How can i now get my eSIM or connection back while being outside of Canada
  • December 4, 2024
So you cannot as you can only aquire an ESIM from a koodo kiosk. However, if you know someone who can pickup an ESIM who is still in Canada, they can just send you a picture of the long barcode on the back and the QR code on the front. After that you simply to go through koodo self serve and replace the sim and then setup new esim. Besides that you would have to wait until you return to Canada.
Thank you oliver for guidance. My brother is in canada and i dont know that either they will handover sim to my brother.
  • December 4, 2024
No problem😎, anyone can actually just go up and ask for a sim, it doesn't have to be you. As long as he's not trying to access your account he should be fine. New ESIMs usually go for $10 but can be $20 if they're not on a discount. 👍
Thanks a lot. I will take this route to resolve my issue. Thanks again
