I selected an exclusive $40 plan offer, but on the confirmation window I see $45. If I select it will I still pay $40?
Did you already set up pre-authorized payments on your account?
I did. I realized now that it’s about the autopay and tried to delete the post, but I couldn’t. So I should be ok right?
We can confirm the plan is eligible with autpay discount. Starting with the next bill, you will get the discount as long as you maintain an autopay method active.
More about the autopay discount can be found here https://www.koodomobile.com/en/help/auto-pay-discount?srsltid=AfmBOorWB0PCKPFf-gSX4q1c3k7RQL5H35KMlX0wlZvvHWWRZlb7fjuM
Thank you! I have another question, after getting the S24 FE for $0 offer, how long do I have to keep this plan for? Will I be allowed to change it to a cheaper plan eventually?
Since you got the phone on a Tab Mid/Plus, you should be able to change to any plan as long as it is a Tab Mid/Plus plan.
Login to the community
