Just like the title, I bought a 50GB now change to 60GB but the usage shows only 8GB.
Thanks.
Your data is likely prorated after changing your plan during your billing cycle. This would help explain why you only have 8GB. https://www.koodomobile.com/en/help/proration
Oww, got it now. So it will become normal from the next billing cycle?
Yes, you will see the full amount in the next billing cycle.
