What is "Unlimited Canada-wide minutes"?
  • Apr 24, 2022 6:46 PM UTC
  • 3 replies
  • 939 views
The plan says “your anytime minutes can be used to call anywhere in Canada.”  Fine, I can call TO anywhere in Canada, but what about calling FROM anywhere in Canada?  And what about calling from the US to Canada?
Best answer by Sophia
Can I CALL from anywhere in Canada, to anywhere in Canada?
Absolutely!
Sophia
  • Apr 24, 2022 6:51 PM UTC
As long as you are in Canada, incoming calls can come from the entire planet and it would still be unlimited.
However, when you are outside of Canada yourself, different rules apply. You would be roaming and you’d be paying the roaming fee (either per minute, or Easy Roam).
  • Apr 24, 2022 7:13 PM UTC
Thanks Sophia, but I’m talking about outgoing calls.  I’ll be taking a road trip across Canada.  Can I CALL from anywhere in Canada, to anywhere in Canada?
Sophia
  • Apr 24, 2022 7:20 PM UTC
Absolutely!
