Hello. I am trying to change my plan. When I try to add long distance perk and click next, it shows no perk added. Should I just select confirm and will this add to my plan? I went back multiple times and tried un selecting and re selecting. Bud doesn't work.
Hi
Please try making the change for the plan and then let us know, so we can try to add the perk for you.
I tried again. Still it says no perk added.
I tried unselecting the perk and respecting. It still said perk not added. I don't see that 29 plan now in plan change section. Can u pls check and tell me what to do
Any update on my request
Hi
We have checked and we didn’t find a $29 plan loaded on your account previously.
Did you follow the steps here to change the plan https://www.koodomobile.com/en/help/changing-your-rate-plan?srsltid=AfmBOop-9UQ7mpvghquiaQi1s9g0IKTge3laRWtLDGuT62qTGAX637h6?
Login to the community
