I pay $15 monthly for add-on UL long distance minutes (US), but would I have the same service if I chose Unlimited long distance Pack as a free Perk???
Hi
Calls from Canada to US are included with the Unlimited Long Distance Pack perk. Just make sure your plan is a Pick your Perk plan and is eligible for the Unlimited Long Distance Pack perk.
There are some area codes that are not included with the Unlimited Long Distance Pack, more info can be found here https://www.koodomobile.com/en/pickyourperk
