Stopping Roaming
  • Oct 10, 2022 9:09 AM UTC
  • 3 replies
  • 234 views
I am in Germany and have both “Data Roaming” and “Mobile data” turned off on my Samsung phone yet I have an “R” showing above my service bars to indicate my phone is roaming. I received a service alert from Koodo yesterday. Are these issued each day the phone is roaming and what further can I do to prevent this?
Allan M
  • Oct 10, 2022 3:45 PM UTC
You just turned off data roaming, that means you can’t use data but your phone would still be able to be used for calls and texts which is why you see the R and why you received the notice the other day.
As long as you don’t send a text, or spend any time on the phone in a call you shouldn’t see any roaming charges though.
So just to be clear, the phone still roams on various networks so it can receive calls and texts but as long as I don't answer any calls or send any texts (I can still read the ones sent to me),  I won't incur roaming charges?
As an aside I received a notification today that I was roaming on a network from France although I have been in Germany all day.
  • Oct 12, 2022 2:02 AM UTC
Correct.
And were you near the Germany and France boarder?
If so it likely connect to the stronger french cell tower
