Roaming options other than Easy Roam?
  • Aug 23, 2022 9:09 PM UTC
  • 2 replies
  • 178 views
I’m travelling to the US and am planning on staying there for ~ 1 month. Easy Roam is $12/day and is way too much for a long periord of stay. Is there any other plan or add-on that includes roaming in the US?
Allan M
  • Aug 23, 2022 11:27 PM UTC
That is it from Koodo.
If you’re staying for a long time usually it’s cheaper to get a prepaid sim from a US carrier.
BobTheElectrician
If you’re not a heavy user, Koodo prepaid with the appropriate boosters can work, if you can guesstimate your consumption. Use it year-round in sunny climes. No expiry on boosters or per diem charge. Current contacts can still call a “Cdn:” number and not have to deal with long distance. You have to verify with US carriers if there is a surcharge for calls to Canada.
