Roaming: cost for local callERS when calling me
  • Aug 26, 2022 5:50 PM UTC
  • 2 replies
  • 135 views
Hi,
simple(?) question: do local people calling me while I am roaming in their country pay as if it was a local/national call for them or as if I were in Canada?
Thank you!
Best answer by Dennis
Anyone calling you will need to dial your Canadian number. So if they are calling you from not-Canada, they will pay long distance, even if your are in the same roaming country.
  • Aug 26, 2022 5:59 PM UTC
  • Aug 26, 2022 7:07 PM UTC
Thanks. I feel this partially defeats the idea of roaming by using your Canadian phone, and I was hoping for better, but it makes sense. Hopefully the locals will be able to contact through apps that use data.
Thanks again.
