If i am travelling longer than 7 days, can i switch from the roaming travel plan package to the $16 a day roaming fee ?
I believe so. The writing is such that you use it, but you cannot. But reps here have repeatedly answered you should be able to use the 16 dollar a day rate thereafter, and even re-add the travel pass if you need it again in the same billing cycle.
Hi
Make sure you add the Easy Roam add-on to your account to avoid pay per use charges as it is not currently active.
