Pre-Paid Call Clarification
  • Oct 21, 2022 6:10 PM UTC
  • 3 replies
  • 301 views
On the prepaid $15 plan, do INCOMING calls have UNLIMITED minutes? (For example, I know if I call, I only have one 100 min, but if someone calls me on the prepaid $15 plan, are the minutes unlimited?
Best answer by Sophia
Yes, the current $15 prepaid plan offers unlimited incoming minutes:
  • 100 minutes of Canada-wide Calling
  • Unlimited incoming calls
However Koodo changes the prepaid plans regularly and you will need to make sure that your plan is the correct one. If it mentions unlimited incoming, you’re golden. If not, wait until one day BEFORE your plan renews, then change to the current $15 plan.
Sophia
  • Oct 21, 2022 6:50 PM UTC
  • Rockstar
  • Oct 21, 2022 7:22 PM UTC
So that’s what unlimited means? Unlimited minutes? I just don’t want to accidentally mistake this and use up all my min
Sophia
  • Oct 21, 2022 7:26 PM UTC
Absolutely. As long as you are in Canada, incoming calls don’t count against your minutes.
