Simple question. There’s a plan I could get which has pay per use data. I want to know what the cost is for each Gig I use. Most plans include 50, 60 or 100G of data with them. I don’t need that much data. I want a plan that includes maybe 2 or 3G like I used to get when I first started with koodo. The only plan that comes close, shopping here online, is a plan with pay per use data but they don’t tell you what the cost is per unit of data. Anyone out there know?
Koodo data payperuse rate is expensive $13 for 100MB.
I wouldn't recommend you to get the payperuse data if you want to use data.
Regarding the plan selection, Koodo currently doesn't offer customization of their plan, you would have to choose a plan on their list.
You are likely better off on Koodo Prepaid. There is a plan with 2GB of data with automatic top-up for $25 a month. https://www.koodomobile.com/en/prepaid-plans
Thank you for taking the time to answer. I see now why koodo does not include the rate in their plan details. Bill Gates couldn’t afford that rate.
Thank you. I will look into koodo prepaid.
Check out Koodo’s sister company Public Mobile - they have much better Prepaid plans than Koodo. They have a fantastic sale on which unfortunately ends today.
