Hi how are you?
I am wondering that I think my plan is expensive and otehr peroson have better plan than me. Could you suggest more valuable or good plan? I think $58 is too expensive.
Please let me know how should I get good plan thank you
Hi how are you?
The plans available are the one you can find on Koodo’s website. If there’s something more interesting, you can switch!
Hi
Feel free to check the available options in self serve, using the steps here https://www.koodomobile.com/en/help/changing-your-rate-plan?srsltid=AfmBOooXEkg02WAXkZp1PoBcWVnjITBkcUUba2QhVLuKYgjrtK13YQpK
There are some plans that eligible with the autopay discount
