My phone support 4G LTE but not VoLTE, am I able to roam in US after 1st July 2022?
  • Jun 28, 2022 10:00 PM UTC
  • 3 replies
  • 266 views
This morning I received a message from Koodo:  You are currently using a 3G phone that connects to 3G networks. This means you’ll no longer be able to use data, text or make phone calls- including 911 when roming in the U.S.
But I am pretty sure that my mobile supports 4G LTE, it is just not supporting VoLTE (because I can’t see such option in the data network setting, and my mobile model is also not in the VoLTE list).
And what is mentioned in koodo webiste: https://www.koodomobile.com/en/help/3gshutdownUS
is confusing, from the information provided there I am not sure if I can roam in US with 4G LTE but without VoLTE.  Does any body know the answer? Thanks
Sophia
  • Jun 29, 2022 12:10 AM UTC
What phone do you have exactly?
  • Jun 29, 2022 12:24 AM UTC
HWAWEI Mate 9, Model Number MHA-AL00
  • Jun 29, 2022 2:35 AM UTC
From the link, what they are saying is you could use “data” LTE normally while roaming in US. However, you couldn’t make/receive call if your device wasn’t on the VoLTE list .
