The addon doesn’t seem available in my self serve. Is there afix?
THX
THX
It’s not in your current add-ons and it is not available to add?
THX
Let me flag a rep to help you out.
Correct. I think a rep at Koodo needs to add it for some reason..
I’m running a Galaxy S23 Ultra, so I imagine it’s compatiple.
THX
Thank You!
Yes, it should be compatible. https://www.koodomobile.com/en/help/volte
Hi
We were unable to identify your account based on your community profile.
Did you use the same email address as for your self serve account to sign up on the Koodo Community?
Hi
No, it appears they are different. How can I privately provide my email?
You will need to create a new account with the same email addess as for your self serve login and log in using self serve (you wlll see the option in the community login page)
Alternatively, you can send us a message on FB or Twitter (X) using the steps at the bottom of this page
I double checked, it is indeed the same email used for both. I logged out, logged in self serve and then logged in community with the same email. TO confirm, I went to create a new account using my self serve email and it said it was already registered.
Yes.
Unfortunately, we could not identify an account with the e-mail address used to log in here. We would recommend scheduling a call-back in order for our team to assist with the situation over the phone.
