International Data/Minutes Roaming vs. Easy Roam
  • Aug 18, 2022 9:02 PM UTC
  • 1 reply
  • 423 views
On my add-ons for my mobile plan, I see both “International Data Roaming,” “International Voice Roaming,” and INTL Easy Roam. If I have Easy Roam activated, do I need the first two? If I keep all three, will I be charged the Easy Roam $15/day as well as any fees for international roaming? Or are the three related? (I’m assuming that I only need the Easy Roam activated.)
Thanks in advance! 😊
1 reply
Allan M
  • Aug 18, 2022 10:51 PM UTC
The first two are access add-ons. The International Data Roaming allows you to access data while roaming, same for the voice so they are needed along with the easyroam add-on.
