When I try to switch to the following $30 promotional plan, I see the error message below. Do I need to call in order to get the new plan?
Hi ​@jchang230948
Have you tried to make the change without selecting the perk?
We can try to add the perk for you afterwards. Please let us know.
Hi ​@Flo Koodo
I only see a single button that says “Choose Plan and Perk”, which immediately leads the the error mentioned. How can I make the change without selecting the perk?
@jchang230948
Which perk are you looking to select with the new plan? Premium Voicemail and Unlimited International SMS (from Canada) are eligible with the new plan
Hi,
I would like to select Premium Voicemail.
I have another account where I would like to make the same change. Should I message you directly?
@jchang230948
We have managed to make the change for you. The perk will be added within 3 business days.
Please note that there will be a proration for the plan change
For the other account, you’d need to create a community account and log in via self serve.
