Do i have unlimited INCOMING minutes?
  • Oct 28, 2022 11:17 PM UTC
  • 17 replies
  • 445 views
Best answer by rileynext
This is what I am referring too
Timo Tuokkola
I'm fairly certain that unless the plan explicitly states “unlimited incoming minutes" that every minute used will count toward you total, whether incoming or outgoing.
  • Rockstar
  • Oct 29, 2022 3:27 PM UTC
Are you sure? I thought I was supposed to have unlimited incoming min?!
Mayumi
  • Oct 29, 2022 4:20 PM UTC
It looks like it's including unlimited incoming calls
  • Rockstar
  • Oct 29, 2022 7:45 PM UTC
Does this help to answer my question? It says minutes unlimited, what does that mean?
Sophia
  • Oct 29, 2022 7:57 PM UTC
@rileynext you have a different plan from the one you posted at first.  Unlimited minutes - both incoming and outgoing - for sure 🙂
  • Rockstar
  • Oct 29, 2022 8:03 PM UTC
@Sophia how can this be? I’ve posted the same plan I’m on…I’m only paying $15 a month
Mayumi
  • Oct 29, 2022 11:35 PM UTC
Can you click " view details" and post a screenshot?
  • Rockstar
  • Oct 30, 2022 12:18 AM UTC
Yes, this is what I found
Sophia
  • Oct 30, 2022 12:48 AM UTC
Edit: WAIT that’s exactly what you did in your first post (plan details). I shall flag a rep, because it definitely shouldn’t be showing “unlimited” in your second screenshot…. Hang tight, they can look into your account and tell you exactly what is included in your plan.
  • Oct 30, 2022 3:25 PM UTC
Hi @rileynext
The  starter plan $15 100 outgoing minutes 250MB 3G speeds includes unlimited incoming minutes Canada wide, here you can find more details: https://www.koodomobile.com/en/rate-plans?INTCMP=KMNew_NavMenu_Shop_Plans
Sophia
  • Oct 30, 2022 3:42 PM UTC
@Flo Koodo but if you look at the 5th post, the screenshot mentions unlimited (no restrictions). That is why we are confused...
Mayumi
  • Oct 30, 2022 4:47 PM UTC
They need to update the way of display of usage on self serve since they are claiming as a self serve driven company 🤨
  • Rockstar
  • Oct 30, 2022 10:33 PM UTC
Hi @rileynext
K, I have that plan, however, when I click “show details” it doesn’t include unlimited incoming minutes in the pop up. Do I still have them, even though they haven’t specified?
  • Rockstar
  • Oct 30, 2022 10:35 PM UTC
  • Rockstar
  • Oct 31, 2022 3:21 AM UTC
(Could someone help clarify this for me? I hope my last two messages helped)
  • Rockstar
  • Oct 31, 2022 5:36 PM UTC
  • Oct 31, 2022 5:54 PM UTC
I doubt anyone here can actually answer your question as no one has access to your account except for Flo, who did not properly address your concerns.
You may have to contact Koodo directly.
