Confusing! please help (minutes question)
  • Oct 23, 2022 11:27 PM UTC
  • 581 views
Can someone who is experienced please clarify for me my plan?
this is what it says I have: just to clarify, I have UNLIMITED minutes for INCOMING calls? 100 min for OUTGOING? Anything else? The fine print of stuff confuses me
Allan M
  • Oct 24, 2022 12:03 AM UTC
Correct, 100min outgoing canada-wide minutes, unlimited incoming.
  • Rockstar
  • Oct 24, 2022 12:24 AM UTC
Does the unlimited incoming include long distance? If someone calls me, it doesn’t use up my 100 min?
Allan M
  • Oct 24, 2022 12:44 AM UTC
Incoming calls can come from any number.
And correct, if they call you it doesn’t use your minutes. If you call them it does.
  • Rockstar
  • Oct 24, 2022 2:26 AM UTC
So sorry, but you’re sure of this?
Allan M
  • Oct 24, 2022 2:42 AM UTC
100% sure!
“If you have a plan with Unlimited Canada-wide minutes, you will not be charged for incoming calls so long as you are in Canada. The caller can be anywhere in the world.”
And https://www.koodomobile.com/en/rate-plans
  • Rockstar
  • Oct 24, 2022 2:45 AM UTC
100% sure!
Ok sounds good! I just wasn’t sure if I had that plan, cause I found the email to be confusing, but if I’m good then that’s good
