I am not happy with my current phone plan and want to downgrade. I have 80 GB of data which is a preposterous number as I only use about 10 GB currently. However, if I try to change my rate plan, Koodo doesn't give me the option to downgrade. Seems a little interesting that their lowest option is 80 GB of data. If I log out and go to the sign up page the options for new customers are basically endless. Including a 44 dollar plan with 30 GB. How do I get this plan?
Page 1 / 1
How much you are paying currently? And do you have a Tab balance in your account with Koodo?
I'm currently paying 55 a month for each line and there's 2 lines. I need to get a long distance plan for the US as well and it's cheaper to add it to a new plan than an existing one.
Also no tab balance.
You need to schedule a callback through Koodo Assist and speak with a rep to see which plans may be offered to you. https://Koo.do/Chat
Login to the community
or
