Hello. Can anyone explain what the following paragraph exactly means?
Does it include the area code or just the main numbers (usually ten digits ###-####) following the area code?
Thanks in advance!
Unlimited Long Distance Pack restrictions: Calls made to phone numbers starting with the following six-digit combinations are not included in this add-on: 559-726, 712-775, 712-432, 605-562, 605-475, and 530-881. Calls made to these numbers will be billed at your standard pay-per-use rate. Macau is not included.
Those 6 combination is the first 6 digit of the number. It inlude the area code and 3 digit after it.
