trash signal at home.
  • Apr 15, 2023 2:39 PM UTC
  • 400 views
SebLemery
So, my roommates and my friends all have great signal at home (Cell service signal) but i do not, and i don’t understand. The Kiosk near my house is useless and they have no idea how to troubleshoot, so i am turning here.
My roommates are with Bell, they get 5/5 signal, my friends are with Telus (5/5), Rogers (5/5), Videotron (5/5), Fido (5/5) but me, with koodo… 0/5, absolutely no signal works at my house, but the moment i go outside at the street corner, it works. I am in the middle of Gatineau, Quebec, There is 5g towers just 2 streets away from me, i can almost feel the radiation keeping my coffee hot. Why the flock would i not be able to receive calls… Its a Koodo Phone too (Samsung, galaxy s20 FE) too…
  • Apr 15, 2023 3:02 PM UTC
So people with Telus have no issues in the same house ? That's weird because Koodo is owned by Telus and uses the same network. Can you try swapping Sim cards with someone else to see if the problem follows
  • Apr 15, 2023 3:18 PM UTC
Koodo doesn't operate on 5G network though. Only 4G (lte) and 3G. If Telus had 5G signal, it doesn't mean your phone could do the same.
I recommend you check network mode and see if the phone was forced to 5G or something similar. A network reset might also help.
Also. as the phone is wifi calling compatible, I recommend you use it when you are at home.https://www.koodomobile.com/en/help/wifi-calling
SebLemery
  • Organizer
  • Apr 15, 2023 3:49 PM UTC
i did swap simcard at the koodoo kiosk. sams issue.
Sophia
  • Apr 15, 2023 4:08 PM UTC
What happens when you borrow another phone (preferably from one of your friends with 5 bars) and use your SIM in that?
  • Apr 15, 2023 4:09 PM UTC
It is possible that your phone is having some connectivity issues. Have you tried removing your case to see if it helps getting you a better signal? What about enabling VoLTE and wifi calling on your device?
