What is the difference between Easy Roam ($16.00 per Day) and Easy Roam Travel Pass ($60,00 per 30 days)?
It is still easy roam, but there is a different pricing scheme.
So if you are going to any of the European countries listed and want to roam for more than 3 days, you should get the travel pass
Hi
Both allow you to use your services included in your Canadian plan while roaming. The difference is that the European Travel Pass has limited countries included and the cost is $60 for 30 days (the counter for the 30 days starts from the moment you start using the services in one of the included countries)
You can check the available travel passes here https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes?srsltid=AfmBOoqqDgdPKveU5AxMBdiCJwK5fviYD28dZ9RwPwCIsoO7F1jTy2s7
Easy Roam International allows you to use your Canadian plan in any country you travel, for $16 a day (You can see the full list of countries covered by Easy Roam International here https://www.koodomobile.com/en/services/easyroam)
Login to the community
