RFB phone help
  • Jun 15, 2023 2:06 AM UTC
  • 4 replies
  • 357 views
I purchased a RFB iPhone and just finished setting it up.
there’s this thing that keeps popping up in my settings saying “Important display message” and when I click on it, it says “unknown part”
I’ve attached a picture of it
Best answer by Allan M
This is “normal” to happen as they sometimes use third party parts.
https://www.koodomobile.com/en/help/certified-pre-owned-phones
Allan M
  • Jun 15, 2023 2:13 AM UTC
  • Jun 15, 2023 2:23 AM UTC
Will that notification go away eventually on my settings screen? If the screen were to have issues later on, will there be an issue with Apple replacing the screen?
  • Jun 15, 2023 2:37 AM UTC
No it will not go away.
During the 1 year warranty if there is an issue with the screen you can bring it to a Telus location for warranty repair.
After the warranty you can bring to Apple or a Mobile Klinic repair shop for replacement
  • Member
  • Jul 2, 2023 1:53 PM UTC
It’s so sketchy to do this without being up front about it. I have the same issue and as I was setting up this iPhone with a seasoned iPhone user with the same phone, the display on my phone is far far different.  So, it’s not the same as a genuine display and I despise Apple for that but I’m not selling them to people either!
