Since yesterday morning, I'm unable to send a text here in Nova Scotia.
I can receive a text, I can call out and receive calls.
It seems it's only texts I can't send.
I reset my network connection. But it didn't help.
Thanks .
Thanks .
I am in Ontario, and for some reason, that will happen to me once in a while. I'll send a text, and the next time I look at my phone, I'll see that it says message not sent. I usually just reboot my phone, and then hit the message not sent and eventually it sends
Thanks! It didn't work. But one thing I noticed is my friends with Virgin and Bell are getting my texts so far .
Ah ok. I took it to Koodo . And it boils down to the fact that it's an LG . Lol
I have a Samsung....so nope.... it's not because it's an LG. Although LG is no longer updating their operating system. So you may want to switch to a different phone manufacturer
So I put my sim into a working Samsung S9 Plus. And the same problem occured.
Maybe it's a SIM card problem?
Maybe. Just go to a koodo or telus store and maybe they can help you. Good luck
