Bell has an app to set time limits on wifi usage, Does Koodo?
Page 1 / 1
No, they don’t have it as of now. If you would like, you could buy a wifi router that has the feature and use with the Koodo internet.
What’s the end goal that you’re trying to accomplish? Maybe we can offer up an alternative.
Thank you Dinh. To answer Allan’s question; it is to set times when my son can use the wifi. Bell’s app allows you to go in to the router and set the times when the wifi is available for a particular device. Great parental app.
Login to the community
or
