We have a koodo wireless home phone line, but have recently added a new koodo cell phone to our account. Can I swap the wireless home phone sim card to the new cell phone to keep that number?
You can use it to make calls, but I doubt you will be able to use it for text messages. The only way is to port out to another carrier and transfer the number back to Koodo.
Hi there ​@kamony
We would not recommend using the Koodo wireless Home phone sim card in a cellphone as the rate plan is not designed for that type of device. We would recommend scheduling a call-back through our Koodo Assist and speak with our dedicated team for a resolution, in order to move and maintain the number.
