Is my phone compatible with the Koodo network?
  • 5 September 2021
  • 4 replies
  • 267 views
Userlevel 2
How can I use my IMEI number to confirm that my phone is compatible with the Koodo Network?
Dinh 2 years ago
The IMEI tool was outdated, I don’t think Koodo would bring it back.
In the mean time, you can try this tool https://willmyphonework.net/
or their official page https://www.koodomobile.com/en/help/my-phone-compatible-koodo
The old tool could tell you if your rig was compatible on at least a limited basis. With newer features, such as 5G, wifi calling and VOLTE, you may need a phone specifically certified by Koodo.
Many older US Android handsets designed for AT&T or T-Mobile networks in the USA work fine for basic data, messaging and voice, but aren’t supported by Koodo for those newer features due to firmware issues.
Is your network compatible with this?
Network
5G
NRN1/2/3/5/7/8/20/25/28/38/40/41/66/77/78/79
4G
LTE-FDD: B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28/66
LTE-TDD: B34/38/39/40/41
3G
WCDMA: B1/2/4/5/6/8/19
CDMA EVDO: BC0/BC1
2G
GSM: B2 /B3 /B5 /B8
Network
5G
4G
3G
CDMA EVDO: BC0/BC1
2G
GSM: B2 /B3 /B5 /B8
The bands are ok. However, you might not be able to use volte and vowifi if the phone wasn't on the Koodo list.
