Please remove the roaming charges on our
December bill as we live on a border city and it constantly picks up US roaming. Thanks.
How much were you charged? And if this happens regularly, I would recommend you disable automatic carrier selection in cell phone and manually select Koodo. More information can be found here https://www.koodomobile.com/en/help/understanding-how-youll-be-charged-while-travelling?
I will flag a rep to look into it as well
$15 on dec 19th. We did not leave canada. Please reverse the charge.
Hi ​@Karen3697
We have looked into it and we couldn’t find a roaming charge on the December bill. Do you see this charge on your PDF bill?
Yes it is on the December bill. Please see the other line ending in 1510. Easy roaming add on $15. Needs to be reversed
@Karen3697
We have double checked and cannot find a roaming charge for this number.
If you are referring to the $15 showing on page 4, this is for Device Care.
Also, feel free to check the available  plans in your self serve account, as you might be eligible for a Canada-US plan: https://www.koodomobile.com/en/help/changing-your-rate-plan
With a Canada-US plan, there will be no fees for when the phone picks a US tower while near the border,. On top of that, you can use your phone without additional charges in US (some exceptions apply). More about Canada-US plans, you can find here https://www.koodomobile.com/en/help/traveling-with-your-canada-us-rate-plan
