Unauthorized pre-authorized payments (How to remove pre-authorized payments)
  • Feb 13, 2022 2:17 PM UTC
  • 8 replies
  • 1261 views
I did a one time payment on my credit card and now Koodo thinks I authorized monthly credit card payment. But I did not!  I looked everywhere on my account and profile and nothing indicates that any pre-authorization has been granted. I want my card removed from the system so I can pay my bills through my bank like I used to.
How do I get my card removed from the system???
Nadia
Best answer by Allan M
If you have it setup you'll see this as soon as you login. Just click "manage payments" then click remove.
Allan M
  • Feb 13, 2022 2:35 PM UTC
  • Feb 13, 2022 2:36 PM UTC
So you’re saying that you never added your credit cxard as a payment method, and when you click on manage payments, it doesn’t show your credit card details? You should be able to hit manage and add your bank too.
Bernard Koodo
@NadiaV You made a one time payment on Jan 9th.  It doesn’t automatically turn your payment method into pre-authorized.  You would have to enable it yourself. Like Allan above showed it would display on your account if it’s enabled. But it is not. I hope this helps.
  • Feb 14, 2022 2:28 PM UTC
Dear Bernard,
That is exactly my problem. There is nothing set up to manage or remove!!!!!   Pre-authorized payment is NOT set up and doesn't show at all. However, you charge my credit card every month.
As a Koodo rep, can you see anything in the background?  I want this removed
thanks
Nadia
Bernard Koodo
@NadiaV As I mentioned the only credit car payment you made with us was the Jan 9th one. Any payments before and after you made through your bank, not through Koodo.  Your account is NOT set up for pre-auth payments.
  • Feb 15, 2022 3:28 AM UTC
Dear Bernard,
thanks
Nadia
How many months have you seen koodo charge your card automatically?
  • Feb 15, 2022 4:25 AM UTC
It’s also possible to setup automatic payments with your bank online. That could be where you had set it up for automatic payments if you see it happening monthly.
  • Feb 16, 2022 11:23 PM UTC
Thanks Goran, that is what happened but I don't remember setting that up.
Thanks
Nadia
