Hello, I have a situation where I will be in International roaming.
- Will I be charged for incoming messages also (no outgoing).
- If I switch on the phone outside Canada, Will it be charged, too?
Please advice,
Please advice,
I am not sure if I am understanding it right.
If I turn on the roaming to receive incoming SMS, What is the roaming fees?
You only pay roaming fee when you actually “use” the roaming service. Sending SMS, using data, making/receiving call will trigger roaming fee.
https://www.koodomobile.com/en/services/easyroam
The stated link states 16$ per day. So should I pay 16$ every day?
If I activate easyroam, De-activate Data roaming, Mobile data and don’t call or phone. Still 16$ will be deducted?
Thanks.
Hi
Any usage made in roaming, except for incoming text messages, triggers the daily Easy Roam fees.
Your phone still needs to connect to the roaming network to receive incoming text messages.
Please check the articles shared by Dinh above for more info about how to prevent unwanted roaming charges.
If you plan to use your Koodo phone abroad, please check also our Easy Roam Travel Passes here https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes?srsltid=AfmBOoq92KLlFSxOY85S8Ez-FFEymcqbGW0qTi5uvTBDcUPhjIHAEYUf
My Apology, your replies are confusing to me.
If I enable Easy roam, I have to enable roaming network as stated by you, I receive only incoming SMS, how much will be the charge?
Thanks!
Just make sure you don’t use data, don’t make/receive calls and don’t send messages. The articles that Dinh shared above explain how to prevent unwanted roaming charges.
I hope this answers your question.
