Hello,
I received a roaming charge on August 10th, I live near the border & have since made the recommended changes on the phone to help prevent these charges.
If this charge could please be reversed, that would be helpful.
Thank you!
Hello,
Thank you!
I’ll flag a rep to take a look
Hello
Sometimes the device is going to catch the network on the other side.
It's a world-wide situation, since the device settings are set to automatically search for the strongest signal.
You can change that in the settings of the device and set it to Manual Network Selection, after it's done searching, you select Koodo and it stays connected to Koodo, even near the border.
I would also advise to keep Data Roaming off while in Canada. This will avoid any accidental charges. We have a great help page here: https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
We verified the day with the charge and confirmed accidental roaming. A credit was applied for the fee and will update within 3-5 minutes in the Self Serve account.
