Long Distance charges for local calls to US with Perk
  • Sep 20, 2023 1:24 AM UTC
  • 167 views
I selected as free perk the option of local calls to USA, however I have been charge for those calls as “Easy Roam”.
Your support is appreciated
Best answer by Mayumi
I have a post plan 10GB and I made 3 calls to US from home in Toronto.
So, you have a $39 plan. It doesn't include International long distance calls.
Mayumi
  • Sep 20, 2023 1:39 AM UTC
What plan do you have?
Did you make calls while you are in Canada or you were in USA?
  • Organizer
  • Sep 20, 2023 1:47 AM UTC
Mayumi
  • Sep 20, 2023 3:47 AM UTC
Timo Tuokkola
If you've been charged for easy roam, that has nothing to do with long distance. It means your phone connected to a US tower. If you were in Canada at the time koodo will credit you for the charges, but you'll need to talk to them directly, either by setting up a callback or via Facebook Messenger.
If you manually search for networks on your phone and select Koodo that should prevent it from connecting to American networks, but you'd need to do so again every time your phone is restarted.
  • Organizer
  • Sep 20, 2023 2:17 PM UTC
how can I reach out Koodo. The option to reach customer service it has been off for few days
Mayumi
  • Sep 20, 2023 6:54 PM UTC
Click Koodo assist to set up a call back.
But, you made long-distance calls without perk or add-on. So the charges are legit. A rep might be help you, but it not guaranteed...
