Does anyone know where I can find a list of charges per minute for long distance calls. Just received my bill and the figure is ridiculously high per minute (about $3.70 per minute).
Yes, the standard PPU rates are all very high. Here you will find the PPU rates vs the rates with the long distance saver:
https://www.koodomobile.com/en/help/long-distance-calling
A fair number of the rates with the saver are competitive. There is also the 28 nation unlimited calling perk for certain plans as an option if you called to any of them. Otherwise you might have better rates with various VoIP options.
Hi there
if you go to this link and select the country which you normally call it will tell you the rate per minute https://www.koodomobile.com/en/help/long-distance-calling?search_api_views_article_search_fulltext=undefined
Login to the community
