double charged for top up..
  • May 12, 2023 11:07 AM UTC
  • 163 views
Last month I top up my account for 25 but it was charged twice ...can you explain why
  • May 12, 2023 12:01 PM UTC
Are you on a prepaid account? Did you click twice when you topped up?
  • May 12, 2023 12:22 PM UTC
Yes it is charged twice..I think it's postpaid
  • May 12, 2023 2:24 PM UTC
Can anyone reply
Why it's charged doubled
  • May 12, 2023 2:34 PM UTC
Well, it's possible you clicked to top up a second time, which would have added 25. If you're topping up your account, you're prepaid. When you log in to your self serve account, does the webpage say Self Serve Prepaid Login?
Worst case you can leave the extra amount on there and it'll go against your balance for next month.
  • May 12, 2023 4:32 PM UTC
Is it refundable or not..
Or I can adjust in next bill
Any solution
  • May 12, 2023 5:08 PM UTC
Not refundable but you can use it when you want.
