Hello there
I was charged easy roam on October 14 and 15 when I was in southern Ontario near the border but I never left Canada. Can these charges be reversed?
Thanks in advance!
I’ll flag a rep to look into it for you since you were still in Canada.
To prevent this in the future you can change your network settings from automatic to manual and then select Koodo
Hi @emevek,
We have looked into the charges you mentioned and as they are accidental roaming we have added a credit to your account, you can check it out in your self serve.
To avoid future charges please make sure the data roaming is turned off in your phone settings and you are manually connecting to the Koodo network.
For more information on how to prevent accidental roaming charges, please check out this article https://community.koodomobile.com/plans-services-232910/easy-roam-understanding-how-you-will-be-charged-while-traveling-7811296
