Charged for long distance calls made on WhatsApp
  • Nov 29, 2022 7:15 PM UTC
  • 3 replies
  • 886 views
My latest bill has $54.45 usage charges for three calls to Spain, but those calls were made on WhatsApp so I should not have been charged. How do I get those charges removed?
Best answer by Bernard Koodo
@pierreb If the calls appear on your invoice (which it seems) than they were made though regular calls. WhatsApp calls would only show up as data since that is what makes the connection possible.
Sophia
  • Nov 29, 2022 7:29 PM UTC
Can you check self serve to see if those calls were made using the phone line instead of Whatsapp? That is usually what happened when charged for minutes...
Bernard Koodo
  • Nov 29, 2022 8:02 PM UTC
That makes no sense.  WhatsApp is an encrypted service over the internet.  Koodo would have no way of knowing where you called...unless you made the calls over the phone network instead.
