voicemail issue
  • Jun 30, 2021 1:30 PM UTC
  • 3 replies
  • 1062 views
How do I disable voicemail on my prepaid phone.  I keep getting a robo call everyday all day.
Best answer by Sophia
I'm not entirely sure if that works for prepaid, but it's worth a try :) Edit: just tried this and it works... So yeah definitely am option!
Alternatively, you can switch to a third party service like Youmail (free for light usage) It has really nice call blocking features plus a robust spam filter. If MilkyWay's solution doesn't work for you, it's worth a try! (Edit: it would work)
Also, make sure you register your number on the do not call list: https://lnnte-dncl.gc.ca/en
  • Jun 30, 2021 1:36 PM UTC
You can follow these instructions to disable your voicemail:
  1. Call your voicemail by holding the number 1 on your dial pad.
  2. Select option 3 to “Manage your greetings”.
  3. Select option 4 to “Manage your Extended Absence Greeting”.
  4. Select option 5 to block callers from leaving a message after hearing the Extended Absence Greeting.
Sophia
  • Jun 30, 2021 2:56 PM UTC
  • Jun 30, 2021 4:15 PM UTC
Thank you for all your replies.  It seems to have worked.
