I don't understand. I just got set up with koodo a week ago and everything has been fine expect my internet. It was supposed to be activated today (may 7) but online it says my internet order is still being processed and my internet won't work. My data also isn't working. I've been on hold for 47 minutes. Isn't there a number I can call to talk to someone right away? This is so irritating.
It sounds like you are trying to set up your home internet. Was it working previously?
Did you set up your modem and router? Did you get the email with the step-by-step instructions to get your service up and running?
Have you tried to reset the modem and router?
https://www.koodomobile.com/en/help/how-to-reset-your-modem-and-your-router
I think you also mentioned your phone data is not working. Was it working previously? Does texting and calling (Incoming and outgoing) work? DId youy port your number in recently?
Did you bring your own phone? Do the APN settings look correct?
https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
We see that the transfer of the number was completed for the cell number. Please follow the suggestion from
For the internet service, you’d need to speak to a rep, so they further look into it. What happens when you try to schedule a call back through the virtual assist with Koodo internet support?
Login to the community
