maximum number of device connections
  • 24 April 2024
  • 2 replies
  • 30 views
Hi, just curious how many devices can I connect to your Boost Wifi6 router.   I have a bunch of smart lights and I seem to be hitting max as it kicks off devices.
Would like to know as at this point I cannot use the router as it does not support enough connections.
How many devices in total do you have? It really depends on the processor of the router and the amount of bandwidth being used for the signal. Smart devices shouldn’t be taking up much bandwidth. Honestly the routers provided by much ISPs aren’t that good or plain suck. You could try a factory reset of the router to see if it helps. Do you just run default wifi 6 network or separate 2.4/5ghz?
Honestly I know they do mostly due to not having the login that gets you access to the good stuff.   Anyway it's sorted out with a different router for now just thought I'd throw it out there.
