How to get old phone invoice
  • 20 April 2024
  • 4 replies
  • 33 views
Hey - I want to find the serial number of a phone I don’t have anymore. I bought it in 2016. Anyone know if Koodo will be able to send me the old invoice? Thx!
I’m not entirely sure if they will be able to send you an invoice that old… but you can schedule a callback and ask. Just a heads-up that there is a fee involved in sending a bill manually :)
Hi @Jacdaw
You should be able to see the service agreements in your self serve account, please check this article and let us know if that helps https://www.koodomobile.com/en/help/viewing-and-downloading-your-customer-service-agreements-csa
Thank you for the article Flo, I have found the invoice.
I’m specifically looking for the serial number of the phone though - I thought it would be on the invoice but it’s not. It says Serial # Not Applicable
Is there a way to find the serial number of the phone I purchased in 2016.
The invoice didn't have the serial number. I believe it might have the phone IMEI on it. You could try to contact Apple directly and ask them about the serial number from the imei.
