my phone is not showing h+ 3G help fix cant recieve calls
my nokia lumina is showing 4g at top corner and should be h+3G how do i fi this
Best answer by Paul Deschamps 19 January 2014, 05:57
If your phones showing 4g it just means your in a 4g area which is a faster connection than 3g & that's it, it won't affect anything and will automatically switch from 4g to 3g when you leave the 4g area. While the phones on try taking out the battery and SIM Card for a minute or so then replace them and try the phone again.
1 reply
