with the new home phone activation, I am not receiving phone calls but i can call out
  • 20 August 2017
  • 65 views
home phone not receiving calls but can call out
Did you port a number over? If so just wait a few hours and everything should be fine.
Did you port a number over? If so just wait a few hours and everything should be fine.I ported the number yesterday,
Did you port a number over? If so just wait a few hours and everything should be fine.Yes I ported a number over, but it was yesterday.
Did you port a number over? If so just wait a few hours and everything should be fine.Porting cellphone numbers usually takes an hour or so. Porting landline numbers takes 2-3 business days. Until the port completes, incoming calls will still go to the landline.
Did you port a number over? If so just wait a few hours and everything should be fine.I will wait a couple of days so I should plug right into the land line??
Did you port a number over? If so just wait a few hours and everything should be fine.You can plug your telephone handset into the wall jack.
