wireless phone sim purchase
  • 21 July 2020
  • 3 replies
  • 108 views
Hi I got wireless phone hub from one of my friend.is it possible to buy only koodos sim for the device and purchase the plans?
Best answer by Dinh 21 July 2020, 19:36
I think someone mentioned that you could buy a BYOD SIM for your WHP at a Koodo kiosk. I would suggest you check in with them at a local store. (You could also call the local store in advance to check).
I believe that you get the hub with the plan no matter what... But you can always keep the other one as a spare.
This might be good option if it works out. I will go and find in nearby store for whp sim card. Thank you
